메인 콘텐츠로 스킵하기
도움말
Sony M-430 Microcassette-Corder Mechanism Deck Replacement
Removing and installing a new mechanism deck in the Sony M-430 Microcassette-Corder.
  • 작성자: Stephen
  • 예상 시간 20 - 40 분
  • 난이도: 어려움
The mechanism deck is responsible for turning the tape at the correct speed so that your recordings record and playback properly. This guide shows you how to replace the mechanism deck and get your microcassette-corder back in working order.
섹션
단계 1 Mechanism Deck  ¶
First, remove the buttons from the mechanism deck so that you can remove it from the case. Find the tabs on each button. Push the tab with a spudger away from the metal connection.
  • First, remove the buttons from the mechanism deck so that you can remove it from the case.
  • Find the tabs on each button.
  • Push the tab with a spudger away from the metal connection.
  • Pull button away from the mechanism deck to remove it.
단계 2  ¶
Remove the mechanism deck by lifting the tab as shown.
단계 2  ¶
  • Remove the mechanism deck by lifting the tab as shown.
