도움말
기술: LG Gram 15" Repairability Assessment
Repairability assessment for the LG Gram 15" performed on January 6, 2017.
We disassembled the LG Gram 15" to see how the Surface/MacBook competitor stacks up.
단계 1 LG Gram 15" Repairability Assessment  ¶
Reference shot with packaging.
  • Reference shot with packaging.
단계 2  ¶
Reference shots. Reference shots. Reference shots.
단계 2  ¶
  • Reference shots.
단계 3  ¶
We first use tweezers to remove the three plastic screw covers and five rubber bumpers. We find eight Phillips screws holding the case together. After removing the screws, we use picks to remove the lower case which is held in with clips.
단계 3  ¶
  • We first use tweezers to remove the three plastic screw covers and five rubber bumpers.
  • We find eight Phillips screws holding the case together.
  • After removing the screws, we use picks to remove the lower case which is held in with clips.
단계 4  ¶
Lower case is removed to view the internals.
단계 4  ¶
  • Lower case is removed to view the internals.
단계 5  ¶
Battery comes out easily—just 6 screws and a connector on the motherboard. SSD is standard and user-upgradable. RAM is also standard and user-upgradable.
단계 5  ¶
  • Battery comes out easily—just 6 screws and a connector on the motherboard.
  • SSD is standard and user-upgradable.
  • RAM is also standard and user-upgradable.
  • At this time, it's cool to note that you can remove the display assembly, speakers, daughterboard, backup battery, motherboard, trackpad, and the fan.
  • Perhaps slightly more useful knowledge: The only component we cannot remove is the keyboard.
단계 6  ¶
We chose the fan + heatpipe combo. 7 screws and 1 plug Followed closely by the motherboard. No surprises. In total < 10 screws, exactly 6 connectors, and the wireless card. There were some alignment pins that required a tiny bit of finagling, but if you know they're there this will take you less than a minute.
단계 6  ¶
  • We chose the fan + heatpipe combo. 7 screws and 1 plug
  • Followed closely by the motherboard. No surprises. In total < 10 screws, exactly 6 connectors, and the wireless card.
  • There were some alignment pins that required a tiny bit of finagling, but if you know they're there this will take you less than a minute.
  • Trackpad's next. It's held in with 4 screws and pops out the top of the lower case.
단계 7  ¶
I/O board, wireless card, speakers, and CMOS battery. The speakers were held in with adhesive to supplement a pair of screws, but it peeled off the case cleanly and we could reuse it when reassembling the unit.
단계 7  ¶
  • I/O board, wireless card, speakers, and CMOS battery.
  • The speakers were held in with adhesive to supplement a pair of screws, but it peeled off the case cleanly and we could reuse it when reassembling the unit.
단계 8  ¶
Keyboard is hidden beneath thin-film insulator taped in place. If you're performing a keyboard replacement, you'll need to buy replacement adhesive for this film. It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle. It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle.
단계 8  ¶
  • Keyboard is hidden beneath thin-film insulator taped in place. If you're performing a keyboard replacement, you'll need to buy replacement adhesive for this film.
  • It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle.
단계 9  ¶
Four screws later, the display assembly is free from the lower case.
단계 9  ¶
  • Four screws later, the display assembly is free from the lower case.
단계 10  ¶
The LG Gram 15&quot; earns a 9 out of 10 on our repairability scale (10 is the easiest to repair): Most components are immediately accessible after removing the lower case cover.
단계 10  ¶
  • The LG Gram 15" earns a 9 out of 10 on our repairability scale (10 is the easiest to repair):
  • Most components are immediately accessible after removing the lower case cover.
  • RAM and SSD are user-replaceable and parts for upgrades are readily accessible.
  • Battery is also user-replaceable.
  • Only Phillips screws are used throughout the device.
  • Manufacturer does not provide user-accessible repair documentation.
