메인 콘텐츠로 스킵하기
도움말
HTC Hero Camera Replacement
더 많은 이미지가 필요함
더 많은 이미지가 필요함
몇몇 추가 이미지는 해당 안내서의 절차를 아주 명백하게 만들 것입니다.
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
This guide will illustrate the appropriate steps necessary to remove a damaged camera and replace it with a functioning unit.
관련 부품
단계 1 Camera  ¶
Locate the four metal tabs on the top and bottom of the camera holding the camera enclosure to the motherboard. Locate the four metal tabs on the top and bottom of the camera holding the camera enclosure to the motherboard. Locate the four metal tabs on the top and bottom of the camera holding the camera enclosure to the motherboard.
단계 1 Camera  ¶
  • Locate the four metal tabs on the top and bottom of the camera holding the camera enclosure to the motherboard.
단계 2  ¶
Using a pair of metal tweezers, simultaneously depress both tabs on one side of the camera enclosure and gently pull up until tabs come free.  Repeat for the opposite side. Using a pair of metal tweezers, simultaneously depress both tabs on one side of the camera enclosure and gently pull up until tabs come free.  Repeat for the opposite side.
단계 2  ¶
  • Using a pair of metal tweezers, simultaneously depress both tabs on one side of the camera enclosure and gently pull up until tabs come free. Repeat for the opposite side.
단계 3  ¶
Pull the released camera enclosure away from the motherboard until it is completely free. Pull the released camera enclosure away from the motherboard until it is completely free.
단계 3  ¶
  • Pull the released camera enclosure away from the motherboard until it is completely free.
단계 4  ¶
Now with camera unit exposed, gently wiggle the camera as you pull away from the phone to remove it. Now with camera unit exposed, gently wiggle the camera as you pull away from the phone to remove it.
단계 4  ¶
  • Now with camera unit exposed, gently wiggle the camera as you pull away from the phone to remove it.
