메인 콘텐츠로 스킵하기
도움말
PlayStation Vita Case Separation
단지 전제 조건
단지 전제 조건
해당 안내서는 단지 다른 안내서의 전제 조건임을 참고하시기 바랍니다.
Separate the front and rear case assemblies of the PlayStation Vita.
Prerequisite Guide
단계 1 Case Separation  ¶
Power off and remove the memory card. Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  • Power off and remove the memory card.
  • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
단계 2  ¶
Using your fingernail or a spudger, pry open the accessory port cover on the top of the device. Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover. Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
단계 2  ¶
  • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
  • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
단계 3  ¶
Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port. Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
단계 3  ¶
  • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
단계 4  ¶
Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases. Continue working your way around the device gently prying it open. There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
단계 4  ¶
  • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
  • Continue working your way around the device gently prying it open.
  • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
단계 5  ¶
Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together. Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
단계 5  ¶
  • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
단계 6  ¶
Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
단계 6  ¶
  • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
단계 7  ¶
Free the battery cable by gently prying up on the connection with a spudger.
단계 7  ¶
  • Free the battery cable by gently prying up on the connection with a spudger.
단계 8  ¶
Separate the front and rear cases.
단계 8  ¶
  • Separate the front and rear cases.
