도움말
PlayStation Vita Right Joystick Replacement
Install the right joystick on the PlayStation Vita.
This guide takes you through the process of installing the right joystick on the PlayStation Vita.
단계 1 Right Joystick  ¶
Using a Phillips #00 screwdriver, remove the two 5.0mm, blue screws from the right joystick.
  • Using a Phillips #00 screwdriver, remove the two 5.0mm, blue screws from the right joystick.
단계 2  ¶
Using a spudger, gently pry the joystick out of the back casing assembly. Using a spudger, gently pry the joystick out of the back casing assembly. Using a spudger, gently pry the joystick out of the back casing assembly.
단계 2  ¶
  • Using a spudger, gently pry the joystick out of the back casing assembly.
