도움말
MacBook Pro 15" Unibody Late 2008 and Early 2009 Left Fan Replacement
Replace the left speaker in your MacBook Pro 15" Unibody Late 2008 and Early 2009.
  • 작성자: Walter Galan
  • 예상 시간 30 분 - 1 시간
  • 난이도: 보통
Replacing a defective fan is pretty easy and will keep your laptop running cool. This guide is for the fan on the left side of the Macbook when in normal operation. It will be the right-hand fan when you are removing it.
단계 1 Left Fan  ¶
Use a spudger to pry the fan connector straight up off the logic board. Be sure to only pry up on the connector itself not on the socket or you may damage the machine.
단계 1 Left Fan  ¶
  • Use a spudger to pry the fan connector straight up off the logic board.
  • Be sure to only pry up on the connector itself not on the socket or you may damage the machine.
  • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
단계 2  ¶
Remove three 3.5 mm Phillips screws securing the left fan to the upper case and logic board.
단계 2  ¶
  • Remove three 3.5 mm Phillips screws securing the left fan to the upper case and logic board.
단계 3  ¶
Lift the fan out of the upper case.
단계 3  ¶
  • Lift the fan out of the upper case.
