메인 콘텐츠로 스킵하기
도움말
기술: How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan
액션 샷
액션 샷
액션 영웅이 되십시오! 해당 안내서는 특정 액션을 더 잘 보여주기 위한 사진들이 필요합니다.
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
Most people who buy these cards experience an annoying buzzing and vibration sound from these cards. The fix is simple!
단계 1 How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan  ¶
remove the three Phillips screws under the fan closest to the video ports of the card
  • remove the three Phillips screws under the fan closest to the video ports of the card
단계 2  ¶
Lift the fan out(will be attached to a small cord but gets out of the way well)  and shim a small cushion under the center circle, between the aluminum cooling fins and the plastic. I used electric tape, rolling it, sticky side in, to form about a 6 layer small square of tape. It shimmed in nicely.
단계 2  ¶
  • Lift the fan out(will be attached to a small cord but gets out of the way well) and shim a small cushion under the center circle, between the aluminum cooling fins and the plastic. I used electric tape, rolling it, sticky side in, to form about a 6 layer small square of tape. It shimmed in nicely.
단계 3  ¶
Reassemble and re-install the card into your computer. It should stop the vibration.
단계 3  ¶
  • Reassemble and re-install the card into your computer. It should stop the vibration.
