도움말
Sony Ericsson W350a Speaker Replacement
더 나은 이미지가 필요함
더 나은 이미지가 필요함
더 나은 사진은 해당 안내서를 향상시킬 것입니다. 사진 촬영, 편집, 또는 새로운 업로드를 도와주십시오!
마크업 사고
마크업 사고
해당 안내서는 더 나은 마크업이 필요합니다. 일부 마크업 주석의 편집 또는 작성을 도와주십시오!
  • 작성자: Ldellos
  • 예상 시간 10 - 15 분
  • 난이도: 보통
단계 1 Speaker  ¶
Flip the phone over and remove the Sony Ericsson sticker that is over the phone's ear speaker. Using a T5 screwdriver, loosen and remove the two screws under the Sony Ericsson sticker by turning them counterclockwise.
단계 1 Speaker  ¶
  • Flip the phone over and remove the Sony Ericsson sticker that is over the phone's ear speaker.
  • Using a T5 screwdriver, loosen and remove the two screws under the Sony Ericsson sticker by turning them counterclockwise.
단계 2  ¶
Using a mini phillips head screwdriver, loosen and remove these screws by turning them counterclockwise.
단계 2  ¶
  • Using a mini phillips head screwdriver, loosen and remove these screws by turning them counterclockwise.
  • Be careful to remember and organize screws to their unique positions in this step as well as future steps.
단계 3  ¶
Insert a prybar in bottom crack between the front and back plates (see picture) and use a gentle upward pull to separate the back case from the front case.
단계 3  ¶
  • Insert a prybar in bottom crack between the front and back plates (see picture) and use a gentle upward pull to separate the back case from the front case.
  • Side buttons/controls may fall from their place in between the back and front casings.
단계 4  ¶
Using a T5 screwdriver, loosen and remove the two screws by turning them counterclockwise.
단계 4  ¶
  • Using a T5 screwdriver, loosen and remove the two screws by turning them counterclockwise.
단계 5  ¶
Using a prybar and a gentle outward motion, separate the front plate from the inner phone workings. After removing the back plate and the front plate, the phone should look like the remaining pictures.
단계 5  ¶
  • Using a prybar and a gentle outward motion, separate the front plate from the inner phone workings.
  • After removing the back plate and the front plate, the phone should look like the remaining pictures.
단계 6  ¶
Using a mini phillips head screwdriver, loosen and remove the screw located on the front number pad by turning it counterclockwise. After removing this screw, the speaker will be free to move and the phone will look like this remaining picture.
단계 6  ¶
  • Using a mini phillips head screwdriver, loosen and remove the screw located on the front number pad by turning it counterclockwise.
  • After removing this screw, the speaker will be free to move and the phone will look like this remaining picture.
  • To reassemble the phone, follow these steps in reverse order.
