메인 콘텐츠로 스킵하기
도움말
PalmOne Zire 72 Battery Replacement
단계 1 Battery  ¶
Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device. Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
단계 1 Battery  ¶
  • Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
단계 2  ¶
Peel back the adhesive label below the camera on the rear to reveal a hidden screw.
단계 2  ¶
  • Peel back the adhesive label below the camera on the rear to reveal a hidden screw.
  • If you peel the entire adhesive off, two holes underneath will be exposed to future damage. Try to preserve the label to reapply later.
  • Alternate Procedure: Underneath the camera, feel for a depression and cut the sticker directly above the depression to reveal the hidden screw.
단계 3  ¶
Use a #00 Philips screwdriver to remove the 2.5mm hidden screw.
단계 3  ¶
  • Use a #00 Philips screwdriver to remove the 2.5mm hidden screw.
단계 4  ¶
Use either end of a a spudger to carefully pry off the camera lens mesh cover.
단계 4  ¶
  • Use either end of a a spudger to carefully pry off the camera lens mesh cover.
단계 5  ¶
Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
단계 5  ¶
  • Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
단계 6  ¶
Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off.
단계 6  ¶
  • Spin the phone around so that the headphone jack is facing you.
  • Run the flat end of the spudger around the entire edge of the device to gently pry the case off.
  • Gently remove the case to avoid damaging it. Do not try to force the case open.
  • The L shaped latches located on the bottom of the device make it hard to remove the case; you should run the spudger around the device's edges again if you are having problems.
단계 7  ¶
Remove the cover by lifting it from right to left. This should be similar to the action of the opening of a book.
단계 7  ¶
  • Remove the cover by lifting it from right to left.
  • This should be similar to the action of the opening of a book.
  • A connector may tear if this is not done carefully. The connector is a brown film connecting the motherboard to the case.
단계 8  ¶
Lift the control pad buttons off of the motherboard.
단계 8  ¶
  • Lift the control pad buttons off of the motherboard.
단계 9  ¶
Wedge the flat end of the spudger underneath the battery and gently pry it out.
단계 9  ¶
  • Wedge the flat end of the spudger underneath the battery and gently pry it out.
  • Be cautious of the red and black wires on the battery, which may rip easily.
  • The battery may have adhesive holding it to the device.
  • The battery connector may rip if the battery is not removed carefully.
단계 10  ¶
Gently disconnect the white component connecting the battery to the motherboard.
단계 10  ¶
  • Gently disconnect the white component connecting the battery to the motherboard.
  • The connector should be pulled upward.
