도움말
Wiko Getaway Screen Panel Replacement
진행 중
진행 중
해당 안내서는 작업중 입니다. 최근 변경사항을 보려면 정기적으로 새로고침하여 주십시오!
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
We will disassemble the whole phone to change the screen.
단계 1 Back cover  ¶
Broken screen ? that's a pity You'll need hot air. Not too much thought, you'll melt the plastic otherwise Now just pry it open SLOWLY and apply heat.
단계 1 Back cover  ¶
  • Broken screen ? that's a pity
  • You'll need hot air. Not too much thought, you'll melt the plastic otherwise
  • Now just pry it open SLOWLY and apply heat.
단계 2 Disconnect stuff  ¶
Nice, I see you've got the cover off Disconnect the battery (not with a metal tool) Disconnect the touch screen ribbon (don't pull hard, you have to lift the plastic bit before)
  • Nice, I see you've got the cover off
  • Disconnect the battery (not with a metal tool)
  • Disconnect the touch screen ribbon (don't pull hard, you have to lift the plastic bit before)
단계 3 Disconnecting more stuff  ¶
Get the battery out (don't bend it too much) Disconnect the LCD ribbon Disconnect the cameras
  • Get the battery out (don't bend it too much)
  • Disconnect the LCD ribbon
  • Disconnect the cameras
단계 4 Screws ! Finally  ¶
Unscrew anything you see Take the SIM trays out Take the motherboard out. You will have to disconnect to ribbon cables
  • Unscrew anything you see
  • Take the SIM trays out
  • Take the motherboard out. You will have to disconnect to ribbon cables
단계 5 Final  ¶
Two screws here To take this guy out, you can use heat again Aaaaand with more heat, you will get the screen panel out !
단계 5 Final  ¶
  • Two screws here
  • To take this guy out, you can use heat again
  • Aaaaand with more heat, you will get the screen panel out !
