도움말
Google Pixel XL Battery Replacement
추천 가이드
추천 가이드
해당 안내서는 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
A guide showing how to replace a non-functional battery in the Google Pixel XL.
  • 작성자: Arthur Shi
  • 예상 시간 1 - 3 시간
  • 난이도: 어려움
Follow this guide to open up the Pixel XL to remove and replace its battery. If your battery is swollen, take appropriate precautions.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
The Pixel XL’s unreinforced display panel is fragile and is attached to the frame with strong adhesive, making repairs difficult. There is a considerable chance of breaking the display, especially if it already has micro-fractures. Be sure to apply plenty of heat and be extremely careful during the prying stage.
단계 1 Battery  ¶
Use the point of a spudger to pry up and disconnect the battery connector. Bend the battery flex cable slightly so that it will not accidentally touch the motherboard. Bend the battery flex cable slightly so that it will not accidentally touch the motherboard.
단계 1 Battery  ¶
  • Use the point of a spudger to pry up and disconnect the battery connector.
  • Bend the battery flex cable slightly so that it will not accidentally touch the motherboard.
단계 2  ¶
Use tweezers to peel up the tape at the top of the interconnect cable. Use tweezers to peel up the tape at the top of the interconnect cable.
단계 2  ¶
  • Use tweezers to peel up the tape at the top of the interconnect cable.
단계 3  ¶
Use the point of a spudger to pry up and disconnect the interconnect cable from the motherboard. To reconnect during reinstallation, align the cable with the socket and use your finger to press down on one side, followed by the other. If done correctly, the cable should be firmly held in place by the socket.
단계 3  ¶
  • Use the point of a spudger to pry up and disconnect the interconnect cable from the motherboard.
  • To reconnect during reinstallation, align the cable with the socket and use your finger to press down on one side, followed by the other. If done correctly, the cable should be firmly held in place by the socket.
단계 4  ¶
Use the point of a spudger to pry up and disconnect the interconnect cable from the bottom daughterboard. You can leave the interconnect cable attached to the daughterboard via the adhesive, or you can completely remove it.
단계 4  ¶
  • Use the point of a spudger to pry up and disconnect the interconnect cable from the bottom daughterboard.
  • You can leave the interconnect cable attached to the daughterboard via the adhesive, or you can completely remove it.
단계 5  ¶
The battery is secured by two strips of double-sided tape. Heat an iOpener and place it on the back of the phone's left edge for two minutes. You may need to reheat and reapply the iOpener.
단계 5  ¶
  • The battery is secured by two strips of double-sided tape.
  • Heat an iOpener and place it on the back of the phone's left edge for two minutes. You may need to reheat and reapply the iOpener.
단계 6  ¶
Flip the phone over. Push an opening pick slowly and firmly down the right edge of the battery (which should be warm). Slide it slightly back and forth to slice through the adhesive. Be careful not to snag the white antenna cable running along the edge of the battery while you are push down on the pick.
단계 6  ¶
  • Flip the phone over.
  • Push an opening pick slowly and firmly down the right edge of the battery (which should be warm). Slide it slightly back and forth to slice through the adhesive.
  • Be careful not to snag the white antenna cable running along the edge of the battery while you are push down on the pick.
  • If you are having a hard time getting the opening pick under the battery, heat and re-apply an iOpener as instructed in the previous step.
  • You can also apply some high concentration isopropyl alcohol to the edge in order to help weaken the adhesive.
  • Once you have loosened the right side of the battery from the case, leave an opening pick in place to prevent the adhesive from re-adhering.
단계 7  ¶
Heat an iOpener and place it on the back of the phone's right edge for two minutes. You may need to reheat and reapply the iOpener.
단계 7  ¶
  • Heat an iOpener and place it on the back of the phone's right edge for two minutes. You may need to reheat and reapply the iOpener.
단계 8  ¶
Flip the phone over. Grasp the loosened right edge of the battery by the corners and slowly swing the right edge upwards. If you feel or see that the battery is bending from the stress, stop and reapply a heated iOpener as directed in the previous step.
단계 8  ¶
  • Grasp the loosened right edge of the battery by the corners and slowly swing the right edge upwards.
  • If you feel or see that the battery is bending from the stress, stop and reapply a heated iOpener as directed in the previous step.
  • You can apply some high concentration isopropyl alcohol to the left edge of the battery to help weaken the adhesive.
  • Once the battery pack is loosened from the adhesive, slowly peel the battery out of the frame.
  • Remove the battery.
단계 9  ¶
To reduce the risk of fire and chemical leakage, do not reuse and reinstall a used battery. To install a battery, apply new adhesive strips and ensure that the battery connector is properly aligned. Tear two adhesive strips from the adhesive card, and apply them to the frame. Do not remove the top liner yet.
단계 9  ¶
  • To reduce the risk of fire and chemical leakage, do not reuse and reinstall a used battery.
  • To install a battery, apply new adhesive strips and ensure that the battery connector is properly aligned.
  • Tear two adhesive strips from the adhesive card, and apply them to the frame. Do not remove the top liner yet.
  • Place the new battery in the recess.
  • Use the flat end of a spudger or your finger to temporarily connect the battery connector to the motherboard.
단계 10  ¶
While the battery is still connected, lift the bottom end of the battery up. Use tweezers to pull all of the adhesive liners off. Carefully lower the battery back into place and press against the edges to activate the adhesive.
단계 10  ¶
  • While the battery is still connected, lift the bottom end of the battery up.
  • Use tweezers to pull all of the adhesive liners off.
  • Carefully lower the battery back into place and press against the edges to activate the adhesive.
  • Use a spudger to pry up and disconnect the battery connector from the motherboard and bend it away slightly.
  • Continue with the reassembly process.
