메인 콘텐츠로 스킵하기
도움말
Sony Vaio PCG-4K1L Keyboard Replacement
This guide will show you how to replace the keyboard on your Sony Vaio.
  • 작성자: Austen
  • 난이도: 보통
단계 1 Keyboard  ¶
Take out the screw in the center of the computer.
단계 1 Keyboard  ¶
  • Take out the screw in the center of the computer.
단계 2  ¶
Flip the computer right side up.
단계 2  ¶
  • Flip the computer right side up.
  • Open screen so that keyboard is visible.
단계 3  ¶
Use a plastic opening tool to gently lift the keyboard at a corner. Make sure you get below the keyboard itself and not just the keys.
단계 3  ¶
  • Use a plastic opening tool to gently lift the keyboard at a corner.
  • Make sure you get below the keyboard itself and not just the keys.
  • Slide the tool around the perimeter of the keyboard and it will start to lift.
단계 4  ¶
Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer. Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
단계 4  ¶
  • Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer.
  • Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
단계 5  ¶
Locate the ribbon cord behind the keyboard. Locate a brown clamp attaching the keyboard to the computer. Use a plastic opening tool to lift the clamp and release the cable.
단계 5  ¶
  • Locate the ribbon cord behind the keyboard.
  • Locate a brown clamp attaching the keyboard to the computer.
  • Use a plastic opening tool to lift the clamp and release the cable.
  • Now the keyboard can be pulled away entirely.
