메인 콘텐츠로 스킵하기
도움말
HP Chromebook 11 G4 SD Card Reader Replacement
Replace the SD card reader of the HP Chromebook 11 G4.
  • 작성자: Jair Herrera
  • 예상 시간 10 - 15 분
  • 난이도: 쉬움
This guide will walk you through how to replace the SD card reader on the HP Chromebook 11 G4. Once you remove the keyboard, the SD card reader is a cinch to replace.
단계 1 SD Card Reader  ¶
Flip up the flap on the ZIP connector with your finger. Gently pull out the ribbon cable. Gently pull out the ribbon cable.
  • Flip up the flap on the ZIP connector with your finger.
  • Gently pull out the ribbon cable.
단계 2  ¶
Remove the two 4 mm Phillips #1 screws. Remove the two 4 mm Phillips #1 screws.
단계 2  ¶
  • Remove the two 4 mm Phillips #1 screws.
단계 3  ¶
Lift the ribbon cable back and out of the way. Pull out the SD card reader.
단계 3  ¶
  • Lift the ribbon cable back and out of the way.
  • Pull out the SD card reader.
