메인 콘텐츠로 스킵하기
도움말
iMac Intel 20" EMC 2266 Front Bezel Replacement
Remove your front bezel to gain access to your iMac's internals.
섹션
단계 1 Front Bezel  ¶
Remove the following 12 screws securing the front bezel to the rear case:
단계 1 Front Bezel  ¶
  • Remove the following 12 screws securing the front bezel to the rear case:
  • Eight 13 mm T8 Torx.
  • Four 25 mm T8 Torx.
  • On the 24" iMac Intel Model A1225, the bottom center two screws are long (26mm), four on sides (two left, two right) are medium (18mm), and the remaining 6 (four top, two bottom corners) are short (14mm).
단계 2  ¶
The front bezel is still attached to the iMac by the microphone cable. Gently lift the front bezel from its top edge off the rear case.
단계 2  ¶
  • The front bezel is still attached to the iMac by the microphone cable.
  • Gently lift the front bezel from its top edge off the rear case.
  • Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
  • Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
  • When reinstalling the front bezel, start at the lower edge and make sure it is flush with the rear case before lowering the top edge onto the iMac.
단계 3  ¶
Disconnect the microphone cable connector, removing tape as necessary.
단계 3  ¶
  • Disconnect the microphone cable connector, removing tape as necessary.
  • For the front bezel to sit properly, be sure to tuck the microphone cable and connector into the void next to the camera board.
