메인 콘텐츠로 스킵하기
도움말
Nikon Coolpix 7900 LCD Screen Replacement
추천 가이드
추천 가이드
해당 안내서는 iFixit 직원들이 뛰어난 안내서로 판명하였습니다.
To detail the process for removing the LCD Screen.
  • 작성자: Kaky Payne
  • 예상 시간 15 분
  • 난이도: 보통
Use this guide to replace the LCD.
단계 1 LCD Screen  ¶
First remove the three 2.5mm screws securing the LCD screen to the substrate. Make sure not to keep hold of the little metal connector by the top left screw!
단계 1 LCD Screen  ¶
  • First remove the three 2.5mm screws securing the LCD screen to the substrate. Make sure not to keep hold of the little metal connector by the top left screw!
  • Carefully flip the screen down to reveal the back of the screen
단계 2  ¶
Disconnect the ribbon cable and gray connector with red and black wires.
단계 2  ¶
  • Disconnect the ribbon cable and gray connector with red and black wires.
  • Depending on your spare part, you may now need to carefully pry the screen back cover off. It is held by a double sided sticky tape on the inside. Be gentle!
