도움말
기술: The myth of the "high capacity" batteries
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
There are plenty of answers regarding the capacity of Gold High Capacity Batteries. I feel that it is time iFixit takes a good look at those as well.
iFixit seems to be the place people turn to for answers. It might be worthwhile to post a test regarding the "Gold High Capacity Batteries". For this test Apple iPhone 5 batteries were used because they were needed for replacement work anyway and would not be wasted to be used for only this test.
The Batteries are offered on multiple outlets like Ebay.com, Amazon.com and various other online stores. The prices for those batteries are usually 50% higher than for a regular battery. That by itself would not be bad, if those batteries truly have higher capacity storage.
단계 1 The myth of the "high capacity" batteries  ¶
Here is the side-by-side of a Gold High Capacity and a standard run-of-the-mill iPhone 5 battery Checking the weight for the Gold battery it was at 0.830oz The standard battery weight 0.848oz.
  • Here is the side-by-side of a Gold High Capacity and a standard run-of-the-mill iPhone 5 battery
  • Checking the weight for the Gold battery it was at 0.830oz
  • The standard battery weight 0.848oz.
단계 2  ¶
Width of the Gold Battery is 32.01 mm vs. 31.5 mm for the standard battery Length of the Gold Battery is 91.72 mm vs. 90.30 mm for the standard battery Thickness of the Gold Battery is 3.86 mm vs. 4.04 mm for the standard battery.
단계 2  ¶
  • Width of the Gold Battery is 32.01 mm vs. 31.5 mm for the standard battery
  • Length of the Gold Battery is 91.72 mm vs. 90.30 mm for the standard battery
  • Thickness of the Gold Battery is 3.86 mm vs. 4.04 mm for the standard battery.
  • Expectation was that the Gold Battery would show difference in physical attributes that would be significant to its claimed increased capacity, which it did not
단계 3  ¶
Gold Battery is fully charged at 4.85 V on an K9201 Fast Battery Charger Activation Circuit Tester Standard battery is fully charged at 4.85 V on an K9201 Fast Battery Charger Activation Circuit Tester For this test a battery connector was simply soldered to a prototype board and wires were soldered to the positive and negative connectors on the board.
단계 3  ¶
  • Gold Battery is fully charged at 4.85 V on an K9201 Fast Battery Charger Activation Circuit Tester
  • Standard battery is fully charged at 4.85 V on an K9201 Fast Battery Charger Activation Circuit Tester
  • For this test a battery connector was simply soldered to a prototype board and wires were soldered to the positive and negative connectors on the board.
단계 4  ¶
The prototype board was then connected to the EBD Constant Current Electronic Load capacity tester. Shown here with the standard battery connected Same connection is made with the Gold Battery (test in progress) Here is the result for the standard battery
단계 4  ¶
  • The prototype board was then connected to the EBD Constant Current Electronic Load capacity tester. Shown here with the standard battery connected
  • Same connection is made with the Gold Battery (test in progress)
  • Here is the result for the standard battery
단계 5  ¶
Here is the result for the Gold Battery.
단계 5  ¶
  • Here is the result for the Gold Battery.
  • Here is the synapse of the test results Standard Battery Title:EB Tester Software Mode:D-CC (Constant Current Discharging) 0.50A 2.90V Begin Volt:4.189V Cutoff Volt:2.904V Capacity:1353mAh Energy:4987mWh Avg Volt:3.69V Total time to reach the cutoff voltage of 2.9V was 2:42:44hours
  • Gold battery. Title:EB Tester Software Mode:D-CC (Constant Current Discharging) 0.50A 2.90V Begin Volt:4.182V Cutoff Volt:2.904V Capacity:1376mAh Energy:4969mWh Avg Volt:3.61V Total time to reach the cutoff voltage of 2.9V was 2:45:33hours
