도움말
MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement
Replace the left fan in the MacBook Pro 15" Retina Display Mid 2012.
  • 작성자: Jake Devincenzi
  • 예상 시간 20 분 - 1 시간
  • 난이도: 보통
Use this guide to install a new left fan (left when the device is resting with the logic board side closest to you.)
단계 1 Left Fan  ¶
Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
단계 1 Left Fan  ¶
  • Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
단계 2  ¶
Remove the following three screws securing the left fan to the logic board:
단계 2  ¶
  • Remove the following three screws securing the left fan to the logic board:
  • One 4.4 mm T5 Torx screw
  • One 5.0 mm T5 Torx screw with 2 mm collar.
  • One 3.9 mm T5 Wide Head Torx screw
단계 3  ¶
Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself. Starting at the top of the cable, slide a plastic opening tool under the left fan cable to free it from the logic board.
단계 3  ¶
  • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Starting at the top of the cable, slide a plastic opening tool under the left fan cable to free it from the logic board.
  • Use caution when freeing the cable, as it is strongly adhered to the logic board. If necessary, use an iOpener or hair dryer to heat the cable in order to soften the adhesive and make it easier to remove.
  • Lift the left fan out of the device.
  • When reinstalling the fan, it's easiest connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
