메인 콘텐츠로 스킵하기
도움말
iMac G5 17" Model A1058 Midplane Assembly Replacement
Remove your midplane assembly to gain access to your display and front bezel.
섹션
단계 1 Midplane Assembly  ¶
Remove the two Phillips screws securing the fan cover to the midplane. The shouldered screw belongs in the lower left corner of the fan cover.
  • Remove the two Phillips screws securing the fan cover to the midplane.
  • The shouldered screw belongs in the lower left corner of the fan cover.
  • Lift the fan cover up off midplane.
단계 2  ¶
Remove the two Phillips screws securing the display data cable to the logic board. Using its black pull tab, pull the display data cable connector straight up off its socket on the logic board.
단계 2  ¶
  • Remove the two Phillips screws securing the display data cable to the logic board.
  • Using its black pull tab, pull the display data cable connector straight up off its socket on the logic board.
단계 3  ¶
Remove the six Phillips screws securing the midplane to the front bezel.
단계 3  ¶
  • Remove the six Phillips screws securing the midplane to the front bezel.
  • The three shorter screws fasten along the top edge of the iMac.
  • The three screws along the top of the iMac often fall down into the front bezel when removed. We recommend using a magnetic screwdriver or placing a strip of duct tape over the tip of your screwdriver to help keep the screws from falling into the front bezel.
단계 4  ¶
Using its attached pull tab, lift the free edge of the midplane assembly slightly out of the front bezel.
단계 4  ¶
  • Using its attached pull tab, lift the free edge of the midplane assembly slightly out of the front bezel.
  • Don't completely remove the midplane assembly just yet.
단계 5  ¶
Push the inverter-to-display cable connector through the hole in the midplane.
단계 5  ¶
  • Push the inverter-to-display cable connector through the hole in the midplane.
  • Lift the now-free midplane assembly out of the front bezel.
