도움말
Opening DXG 567V HD Camera Case
진행 중
진행 중
해당 안내서는 작업중 입니다. 최근 변경사항을 보려면 정기적으로 새로고침하여 주십시오!
회원-기여 안내서
회원-기여 안내서
해당 안내서는 저희 커뮤니티의 멋진 회원께서 작성하였습니다. iFixit 직원이 관리하지 않습니다.
Just a brief how-to opening of the DXG 567V HD Camcorder.
단계 1 Opening DXG 567V HD Camera Case  ¶
This camcorder is a 720p HD camcorder that costs very little. This camcorder is a 720p HD camcorder that costs very little.
  • This camcorder is a 720p HD camcorder that costs very little.
단계 2  ¶
The first step is to open the hatch for the batteries. to do this, on the right side there is a door that you push down on and it opens. Now remove the two s screws highlighted in red.
단계 2  ¶
  • The first step is to open the hatch for the batteries. to do this, on the right side there is a door that you push down on and it opens.
  • Now remove the two s screws highlighted in red.
단계 3  ¶
Now at the bottom of the device there is a screw circled in red that is hidden under a warranty sticker (in blue).
단계 3  ¶
  • Now at the bottom of the device there is a screw circled in red that is hidden under a warranty sticker (in blue).
  • THIS STEP WILL VOID YOUR WARRANTY!
단계 4  ¶
On the top side there is a screw (circled) that is under a little black dot. Peel that dot off with a knife or pointed spudger.
단계 4  ¶
  • On the top side there is a screw (circled) that is under a little black dot. Peel that dot off with a knife or pointed spudger.
단계 5  ¶
On the left side there is another screw under the black dot.
단계 5  ¶
  • On the left side there is another screw under the black dot.
단계 6  ¶
On the right side (battery door hatch side), there is another screw under a black dot.
단계 6  ¶
  • On the right side (battery door hatch side), there is another screw under a black dot.
단계 7  ¶
Now carefully using a spudger or case opening tool, carefully rise the front bezel from the back casing by working around the device.
단계 7  ¶
  • Now carefully using a spudger or case opening tool, carefully rise the front bezel from the back casing by working around the device.
단계 8  ¶
When lifting the front off the hatch for the batteries will come off. when putting it back together put the spring (in green) in between the rail holders (in red) then slip it on the rail (yellow).
단계 8  ¶
  • When lifting the front off the hatch for the batteries will come off. when putting it back together put the spring (in green) in between the rail holders (in red) then slip it on the rail (yellow).
