도움말
Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement
This guide shows how to replace the fan and attached heatsink.
  • 작성자: Royce Gunter
  • 예상 시간 15 - 25 분
  • 난이도: 보통
This guide will show you how to replace your fan and heatsink. This will restore the cooling capabilities of the laptop close to factory conditions. Before starting the steps make sure the Laptop is fully powered off.
단계 1 Fan and Heatsink  ¶
Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place. Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place. Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place.
  • Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place.
단계 2  ¶
Remove the wire connecting the fan to the motherboard. Remove the wire connecting the fan to the motherboard.
단계 2  ¶
  • Remove the wire connecting the fan to the motherboard.
단계 3  ¶
Gently remove the fan and heat sink from the motherboard. On reassembly, be sure to clean the CPU and heat sink and reapply thermal compound to the CPU. Follow this guide to learn how.
단계 3  ¶
  • Gently remove the fan and heat sink from the motherboard.
  • On reassembly, be sure to clean the CPU and heat sink and reapply thermal compound to the CPU. Follow this guide to learn how.
