주요 콘텐츠로 건너뛰기
hp pavilion 15-cc023cl Headphone Jack Replacement
필요한 것
  1. hp pavilion 15-cc023cl Headphone Jack Replacement, Battery: 1 단계, 이미지 2개 중 1개 hp pavilion 15-cc023cl Headphone Jack Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. hp pavilion 15-cc023cl Headphone Jack Replacement: 2 단계, 이미지 1개 중 1개
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. hp pavilion 15-cc023cl Headphone Jack Replacement: 3 단계, 이미지 2개 중 1개 hp pavilion 15-cc023cl Headphone Jack Replacement: 3 단계, 이미지 2개 중 2개
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. hp pavilion 15-cc023cl Headphone Jack Replacement: 4 단계, 이미지 2개 중 1개 hp pavilion 15-cc023cl Headphone Jack Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the port connecting the battery and the motherboard and then remove.
  5. hp pavilion 15-cc023cl Headphone Jack Replacement, Hard Drive: 5 단계, 이미지 1개 중 1개
    • Use a spudger to lift the latch that holds the hard drive cable in place.
  6. hp pavilion 15-cc023cl Headphone Jack Replacement: 6 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to pry the hard drive out.
  7. hp pavilion 15-cc023cl Headphone Jack Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the hard drive cable.
  8. hp pavilion 15-cc023cl Headphone Jack Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the plastic wedges up on both sides of the hard drive.
  9. hp pavilion 15-cc023cl Headphone Jack Replacement, Motherboard: 9 단계, 이미지 1개 중 1개
    • Locate the motherboard.
  10. hp pavilion 15-cc023cl Headphone Jack Replacement: 10 단계, 이미지 2개 중 1개 hp pavilion 15-cc023cl Headphone Jack Replacement: 10 단계, 이미지 2개 중 2개
    • Use a PH0 screwdriver to unscrew the three 3 mm Phillips head screws located on the fan.
  11. hp pavilion 15-cc023cl Headphone Jack Replacement: 11 단계, 이미지 1개 중 1개
    • Use a PH1 screwdriver to unscrew the four 3mm Phillips head screws located on the processor cover.
    • Disconnect the cable.
  12. hp pavilion 15-cc023cl Headphone Jack Replacement: 12 단계, 이미지 1개 중 1개
    • Disconnect the plastic arm attached to the processor and remove.
    • Disconnect the cable attaching the fan to the motherboard and remove.
  13. hp pavilion 15-cc023cl Headphone Jack Replacement: 13 단계, 이미지 1개 중 1개
    • Use a PH1 screwdriver to unscrew one 3mm Phillips head screws on Wifi card.
    • Disconnect the Wifi card.
    • Be careful not to break any of the connectors.
  14. hp pavilion 15-cc023cl Headphone Jack Replacement: 14 단계, 이미지 3개 중 1개 hp pavilion 15-cc023cl Headphone Jack Replacement: 14 단계, 이미지 3개 중 2개 hp pavilion 15-cc023cl Headphone Jack Replacement: 14 단계, 이미지 3개 중 3개
    • Disconnect the 5 cables to keyboard and speakers.
    • You may have to pry some up with the spudger.
  15. hp pavilion 15-cc023cl Headphone Jack Replacement: 15 단계, 이미지 2개 중 1개 hp pavilion 15-cc023cl Headphone Jack Replacement: 15 단계, 이미지 2개 중 2개
    • Use a PH1 screwdriver to unscrew six 3 mm Phillips head screws on the motherboard.
  16. hp pavilion 15-cc023cl Headphone Jack Replacement: 16 단계, 이미지 1개 중 1개
    • Use the iFixit opening tools to pry motherboard from back of laptop.
  17. hp pavilion 15-cc023cl Headphone Jack Replacement: 17 단계, 이미지 1개 중 1개
    • Disconnect SD and USB card cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Stephanie Henry
회원 가입일: 10/02/18
1,122 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 31
전체 시간: 1,785
