주요 콘텐츠로 건너뛰기
hp spectre 13-3010dx Track Pad Replacement
필요한 것
  1. hp spectre 13-3010dx Track Pad Replacement, Removal of the Back Case: 1 단계, 이미지 1/2 hp spectre 13-3010dx Track Pad Replacement, Removal of the Back Case: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Put on Anti Static Wrist Strap.
    • It is always a good idea to ground yourself when working with electronics to prevent static buildup. You wear this strap to protect you and your device from accidental electrostatic discharge (ESD) damage during repairs.]
    • Flip Computer Upside down.
    • Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
  2. hp spectre 13-3010dx Track Pad Replacement: 2 단계, 이미지 1/2 hp spectre 13-3010dx Track Pad Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to lift the back case off.
    • Use the plastic opening tools first; metal spudgers can damage your device.
  3. hp spectre 13-3010dx Track Pad Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the six 2.0mm silver screws and the two 3.2 mm black screws using the PH00 Phillips Screw Head.
  4. hp spectre 13-3010dx Track Pad Replacement: 4 단계, 이미지 1/1
    • Gently unplug from CONO851 plug, using the plastic opening tool.
  5. hp spectre 13-3010dx Track Pad Replacement: 5 단계, 이미지 1/2 hp spectre 13-3010dx Track Pad Replacement: 5 단계, 이미지 2/2
    • Gently lift up the battery and remove using the plastic opening tools.
  6. hp spectre 13-3010dx Track Pad Replacement, Track Pad: 6 단계, 이미지 1/1
    • Unscrew the five 2.3 mm screws using the PH000 screw head.
  7. hp spectre 13-3010dx Track Pad Replacement: 7 단계, 이미지 1/1
    • Lift up the latch using the nylon spudger.
  8. hp spectre 13-3010dx Track Pad Replacement: 8 단계, 이미지 1/1
    • Disconnect the ribbon.
  9. hp spectre 13-3010dx Track Pad Replacement: 9 단계, 이미지 1/1
    • Lift out the track pad.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Laurisa Titterud
회원 가입일: 01/25/16
1,257 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 1,363
