소개
Use this guide if your track pad is damaged or unresponsive. Make sure you are wearing the Anti-Static Wrist Strap and remove the battery to avoid damaging the electronics.
필요한 것
이 단계에 사용된 도구:Anti-Static Wrist Strap$7.95
Put on Anti Static Wrist Strap.
Flip Computer Upside down.
Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
Remove the six 2.0mm silver screws and the two 3.2 mm black screws using the PH00 Phillips Screw Head.
다른 한 분이 해당 안내서를 완성하였습니다.
