주요 콘텐츠로 건너뛰기
iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement
필요한 것
  1. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement, M.2 NVMe Drive: 1 단계, 이미지 1/2 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement, M.2 NVMe Drive: 1 단계, 이미지 2/2
    • Lay the desktop on its side with the glass panel facing up.
    • Remove the single screw.
  2. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: 2 단계, 이미지 1/2 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: 2 단계, 이미지 2/2
    • Remove the glass side by pivoting it up with the bottom side still seated in the notches.
    • Lift the glass side out of the notches and set it to the side.
  3. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: 3 단계, 이미지 1/3 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: 3 단계, 이미지 2/3 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: 3 단계, 이미지 3/3
    • Locate the M.2 drive that is right above the CPU.
    • Remove the screw on the edge of the drive.
  4. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: 4 단계, 이미지 1/2 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: 4 단계, 이미지 2/2
    • The drive should lift up on the edge where the screw was.
    • Pull the drive out at an angle from the motherboard.
  5. iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: 5 단계, 이미지 1/2 iBUYPOWER Trace 4 9310 M.2 NVMe Drive Replacement: 5 단계, 이미지 2/2
    • Line the new drive up with the slot and gently slide it in.
    • Use one finger to hold the drive down while you screw it back in.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kylie F
회원 가입일: 02/25/21
225 평판
안내서 1개 작성함
댓글 한 개
Thank you, Kilie, for the clear step-by-step instructions, together with pictures, for NVMe SSD installation.
George
George Meier - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 18
30일 전: 119
전체 시간: 2,640
