소개
Replace a faulty display inverter with the display attached to your iBook.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Remove the pieces of tape holding the inverter and the inverter cables to the clutch hinges.
다른 6명이 해당 안내서를 완성하였습니다.
