주요 콘텐츠로 건너뛰기
iBook G3 Clamshell CD Faceplate Replacement
필요한 것
  1. iBook G3 Clamshell CD Faceplate Replacement, Battery: 1 단계, 이미지 1/1
    • Use a coin to turn both battery locking screws 90 degrees to the left.
    • Remove the battery cover.
    • Remove the battery from the computer by pulling up on the plastic tab.
  2. iBook G3 Clamshell CD Faceplate Replacement, CD Faceplate: 2 단계, 이미지 1/1
    • Use a straightened paperclip to manually eject the CD-ROM tray.
  3. iBook G3 Clamshell CD Faceplate Replacement: 3 단계, 이미지 1/1
    • Remove the single black Phillips screw from the center of the CD-ROM bezel.
  4. iBook G3 Clamshell CD Faceplate Replacement: 4 단계, 이미지 1/1
    • Grasp the CD-ROM bezel and rotate it upward to remove it from the drive.
    If you rotate the bezel upward as described- you SNAP OFF THE TAB THAT YOU REMOVED THE SCREW FROM, which is what ATTACHES the bezel to the drive!!!. THANKS!
    quayd - 답글
결론
다른 6명이 해당 안내서를 완성하였습니다.
첨부 문서
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 2개
There are two small black phillips screws which ALSO need to be removed ...... on some models. Although appearing identical, these covers are "similar" but NOT interchangeable between models of CD-Rom.
John Foster - 답글
Help I've broke my drive cover and it won't go back on how do I fix that
Mr. Yee Macinuwm - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 10,052
