이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a coin to turn both battery locking screws 90 degrees to the left.
Remove the battery cover.
Remove the battery from the computer by pulling up on the plastic tab.
Remove the single black Phillips screw from the center of the CD-ROM bezel.
Grasp the CD-ROM bezel and rotate it upward to remove it from the drive.
다른 6명이 해당 안내서를 완성하였습니다.
첨부 문서
댓글 2개
There are two small black phillips screws which ALSO need to be removed ...... on some models. Although appearing identical, these covers are "similar" but NOT interchangeable between models of CD-Rom.
Help I've broke my drive cover and it won't go back on how do I fix that
