주요 콘텐츠로 건너뛰기
iBook G3 Clamshell Hard Drive Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iBook G3 Clamshell Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Use a coin to turn both battery locking screws 90 degrees to the left.
    • Remove the battery cover.
    • Remove the battery from the computer by pulling up on the plastic tab.
  2. iBook G3 Clamshell Hard Drive Replacement, Airport Card: 2 단계, 이미지 1/1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
    • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
  3. iBook G3 Clamshell Hard Drive Replacement: 3 단계, 이미지 1/1
    • If your computer does not have an airport card, you can skip the next two steps.
    • Grasp the clear plastic tab on the airport card and pull up and toward the display.
    Note to those who want to install an airport card to a laptop here that doesn't have a card. The proper orientation is with the bar code facing up, and the "Airport" artwork and logo facing down. There are small slots on the bottom of the card that fit into pins below the trackpad. You will know it is properly slotted because the top of the card will touch the handles of the RAM shield.
    The proper orientation of the antenna is that it is plugged in from the right side of the top of the airport card, with the cable winding up from the right to the left.
    Marissa Stardance - 답글
  4. iBook G3 Clamshell Hard Drive Replacement: 4 단계, 이미지 1/1
    • Hold the airport card in one hand and use your other hand to remove the antenna cable.
  5. iBook G3 Clamshell Hard Drive Replacement, Keyboard: 5 단계, 이미지 1/1
    • Remove the two Phillips screws that secure the RAM shield.
  6. iBook G3 Clamshell Hard Drive Replacement: 6 단계, 이미지 1/1
    • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
  7. iBook G3 Clamshell Hard Drive Replacement: 7 단계, 이미지 1/1
    • Pull up the keyboard connector cable by its clear plastic loop.
  8. iBook G3 Clamshell Hard Drive Replacement, Upper Case: 8 단계, 이미지 1/1
    • Use a straightened paperclip to manually eject the CD-ROM tray.
  9. iBook G3 Clamshell Hard Drive Replacement: 9 단계, 이미지 1/1
    • Turn the computer over so that the bottom is facing up.
    • Remove the following Torx screws:
    • Four short T8 Torx near the battery compartment.
    • Two long T8 Torx near the hinges.
  10. iBook G3 Clamshell Hard Drive Replacement: 10 단계, 이미지 1/1
    • Pull the CD-ROM drive tray partly out.
    • Remove the silver Phillips screw from the plastic casing.
    Note to people whose Clamshell ibook doesn't have the CD tray cover any more -- you do not have to open the drive for this part because when you flip the machine to remove the screw, it will be visible. The cover normally obscures this part.
  11. iBook G3 Clamshell Hard Drive Replacement: 11 단계, 이미지 1/1
    • Turn the computer over.
    • Remove the three Phillips screws.
    Please note: these screws can (and may!) strip easily, so take extra care in removing them!
    LambdaCalculus - 답글
  12. iBook G3 Clamshell Hard Drive Replacement: 12 단계, 이미지 1/1
    • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    In part 1, you can use a small flat-blade screwdriver to lift the locking bar. This will not put pressure on the cable itself. Each end of the locking bar will click when it has been lifted sufficiently.
    Don Solomon - 답글
  13. iBook G3 Clamshell Hard Drive Replacement: 13 단계, 이미지 1/1
    • Loosen the trackpad clamp by pulling the top piece up slightly, freeing the trackpad ribbon.
    • Slide the orange trackpad ribbon out of the clamp.
    Before going to the next step, remove 4 T8 screws from bottom of case.
    gestler - 답글
  14. iBook G3 Clamshell Hard Drive Replacement: 14 단계, 이미지 1/1
    • Do not lift the upper case too far without first disconnecting the audio cable.
    • Push out the rim of the lower case and pull up on the upper case, grasping it just to the left of the optical drive.
    • Repeat the above step on the upper left corner of the upper case, grasping the bottom left corner of the upper case.
  15. iBook G3 Clamshell Hard Drive Replacement: 15 단계, 이미지 1/1
    • Disconnect the audio cable.
  16. iBook G3 Clamshell Hard Drive Replacement: 16 단계, 이미지 1/1
    • Grasp the upper case on either side of the keyboard space and rotate up and away from the screen.
    • You may be thinking you're about to break your upper case. Not to worry - the tabs holding the upper and lower cases together are very strong. Simply apply even pressure and continue to rotate the upper case up and away from the screen until it comes free.
    When replacing the upper case, test the trackpad button to make sure it clicks before proceeding. If it does not operate properly, remove the upper case and reattach it.
    Don Solomon - 답글
    Once you free the back half, pull the the case forward, not up so much, or you’ll break the tabs on the sides by the optical drive on the right, and about the same place on the left.
    Rick Karrer - 답글
  17. iBook G3 Clamshell Hard Drive Replacement, Optical Drive: 17 단계, 이미지 1/1
    • If the optical drive is not open, use a straightened paperclip to open it now.
    • Remove the 5 mm standoff.
  18. iBook G3 Clamshell Hard Drive Replacement: 18 단계, 이미지 1/1
    • Disconnect the optical drive cable from the logic board.
  19. iBook G3 Clamshell Hard Drive Replacement: 19 단계, 이미지 1/1
    • Lift up on the optical drive while sequentially pushing the small plastic tabs one after another toward the screen to free one side of the drive.
    • Lift up the side of the optical drive you just freed and slide the drive out and away from the screen.
    • When reinstalling the optical drive, be sure that the drive tray is out far enough to slide under the lower casing rim.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
  20. iBook G3 Clamshell Hard Drive Replacement, Modem: 20 단계, 이미지 1/1
    • Remove the following Phillips screws:
    • Remove the longer Phillips screw from the middle-rear of the modem shield.
    • Remove the three identical Phillips screws, two on either side of the EMI fingers, and the remaining one on the right side of the modem shield.
    • Remove the larger Phillips screw that secures the EMI fingers to the modem board.
    • Remove the EMI fingers.
  21. iBook G3 Clamshell Hard Drive Replacement: 21 단계, 이미지 1/1
    • Peel the modem shield away from the metal framework below, working from the right front and moving to the left.
  22. iBook G3 Clamshell Hard Drive Replacement: 22 단계, 이미지 1/1
    • Remove the Phillips screw from the left side of the modem.
    • Pry up the right side of the modem.
  23. iBook G3 Clamshell Hard Drive Replacement: 23 단계, 이미지 1/1
    • Lift the modem partially out and disconnect the cable on the left side.
  24. iBook G3 Clamshell Hard Drive Replacement, Display: 24 단계, 이미지 1/1
    • Remove the Phillips screw from the left hinge.
    • Peel up the airport cable from beneath the yellow tape.
  25. iBook G3 Clamshell Hard Drive Replacement: 25 단계, 이미지 1/1
    • Disconnect the large display data cable from the logic board and deroute it from the plastic and metal tabs.
  26. iBook G3 Clamshell Hard Drive Replacement: 26 단계, 이미지 1/1
    • Disconnect the backlight cable from the logic board and deroute it.
  27. iBook G3 Clamshell Hard Drive Replacement: 27 단계, 이미지 1/1
    • Remove the three small Phillips screws from the clutch cover.
    When reinstalling, hold the display so the clutch cover is flush with the panel below. Make sure no wires are caught before tightening the screws.
    Don Solomon - 답글
    Note that there are small hooks that hold the clutch cover down. When reinstalling, be sure to hook the cover to them from the back, or you will have problems with the cover catching on the lid as you close it.
    Brandon Dusseau - 답글
    I second this..
    Jamba -
    When putting the computer back together, I recommend screwing down the clutch cover before the larger display screws, since the clutch cover can move around a lot.
  28. iBook G3 Clamshell Hard Drive Replacement: 28 단계, 이미지 1/1
    • Finally, support the display with one hand while unscrewing the last Phillips screw from the right hinge (push the display gently down to avoid putting pressure on the screw).
    • Remove the display assembly.
    • When re-installing the display assembly, make sure that the clutch cover goes over the white plastic tabs protruding from the rear underside of the laptop.
  29. iBook G3 Clamshell Hard Drive Replacement, EMI Shield: 29 단계, 이미지 1/1
    • Remove the two small Phillips screws from the RJ-11 board.
    these two screws are acually long screws.
    Jamba - 답글
  30. iBook G3 Clamshell Hard Drive Replacement: 30 단계, 이미지 1/1
    • Push out the lower case rim and pull the RJ-11 board out of the computer.
  31. iBook G3 Clamshell Hard Drive Replacement: 31 단계, 이미지 1/1
    • Deroute the speaker cable from the metal framework and disconnect it from the logic board.
    I don’t believe you need to deroute the speaker cable; just disconnect it from the logic board and leave it taped on where it is.
    John Hagan - 답글
    I second this.
    Maxime Abbey -
  32. iBook G3 Clamshell Hard Drive Replacement: 32 단계, 이미지 1/1
    • There are six screws to remove (if you have an iBook without Firewire the screw circled in orange will not be present):
    • Two short, flat-headed Phillips screws near the battery compartment.
    • One short, round-headed Phillips near the speaker cable connector. (This is present on some models, but not others - especially the older ones)
    • One short, flat-headed Phillips between the ethernet and USB ports.
    • One short, flat-headed Phillips to the left of the hole-y (polite laughter) area.
    • One long, round-headed Phillips screw near the power receptacle.
    When reassembling, don’t forget to re run the audio cable through the hole in the EMI shield, the one just above the screw with the orange circle on the left side of the picture. Ask me how I know.
    stevesontheroad - 답글
  33. iBook G3 Clamshell Hard Drive Replacement: 33 단계, 이미지 1/1
    • Lift the right side of the EMI shield up and pull it out of the computer.
    Note when reassembling, it is easy to bend the small shield tabs in the upper left area following the curve of the case when putting it back. So be careful.
  34. iBook G3 Clamshell Hard Drive Replacement, Hard Drive: 34 단계, 이미지 1/1
    • Remove the three 5 mm standoffs securing the hard drive to the logic board.
    If you don’t have a nut driver, loosen the standoffs with needle nosed pliers, and then thread a screw from one of the earlier steps into the standoff until it is snug, then unscrew the screw and the standoff as one.
  35. iBook G3 Clamshell Hard Drive Replacement: 35 단계, 이미지 1/1
    • Pull the hard drive cable up from the logic board, using the plastic loop.
    • Lift the hard drive, with metal bracket attached, from the logic board.
    Note that when reassembling the computer, there are small slots on the bottom of the hard drive bay frame that slot in to very small slots on the motherboard / logic board. If you have trouble putting the hard drive frame back on, check for these slots.
결론
다른 15명이 해당 안내서를 완성하였습니다.
첨부 문서
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 한 개
This is a nightmare just to change a hard drive.
Corey Butler - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 23,667
