주요 콘텐츠로 건너뛰기
iBook G4 12" 1.33 GHz Keyboard Replacement
필요한 것
  1. iBook G4 12" 1.33 GHz Keyboard Replacement, Battery: 1 단계, 이미지 1/2 iBook G4 12" 1.33 GHz Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Lay your iBook upside down on a flat surface.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G4 12" 1.33 GHz Keyboard Replacement, Keyboard: 2 단계, 이미지 1/2 iBook G4 12" 1.33 GHz Keyboard Replacement, Keyboard: 2 단계, 이미지 2/2
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. iBook G4 12" 1.33 GHz Keyboard Replacement: 3 단계, 이미지 1/1
    • Remove the four silver Phillips screws that secure the RAM shield.
  4. iBook G4 12" 1.33 GHz Keyboard Replacement: 4 단계, 이미지 1/1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
결론
다른 10명이 해당 안내서를 완성하였습니다.
첨부 문서
Walter Galan
694,638 평판
안내서 1,203개 작성하였습니다
댓글 한 개
The screw is stripped. What should I do?
TheYootz Media Group - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 12
전체 시간: 10,276
