주요 콘텐츠로 건너뛰기
iBook G4 12" 1.33 GHz Keyboard Replacement
필요한 것
  1. iBook G4 12" 1.33 GHz Keyboard Replacement, Battery: 1 단계, 이미지 1/2 iBook G4 12" 1.33 GHz Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Lay your iBook upside down on a flat surface.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G4 12" 1.33 GHz Keyboard Replacement, Keyboard: 2 단계, 이미지 1/2 iBook G4 12" 1.33 GHz Keyboard Replacement, Keyboard: 2 단계, 이미지 2/2
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. iBook G4 12" 1.33 GHz Keyboard Replacement: 3 단계, 이미지 1/1
    • Remove the four silver Phillips screws that secure the RAM shield.
  4. iBook G4 12" 1.33 GHz Keyboard Replacement: 4 단계, 이미지 1/1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
결론
다른 10명이 해당 안내서를 완성하였습니다.
첨부 문서
Walter Galan
684,330 평판
안내서 1,203개 작성하였습니다
One Comment
The screw is stripped. What should I do?
TheYootz Media Group - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 10,138
