소개
Remove your rear display bezel to access your display's internals.
필요한 것
Lay your iBook upside down on a flat surface.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
다른 3명이 해당 안내서를 완성하였습니다.
