소개
Replace a faulty display inverter with the display attached to your iBook.
Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Remove the pieces of tape holding the inverter and the inverter cables to the clutch hinges.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
