소개
The motherboard includes all ports except the DC-In board.
필요한 것
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Remove the following 7 screws from the edges of the keyboard area.
Three 2 mm Phillips along the right edge.
One 4.5 mm Phillips underneath where the magnet was.
One 6 mm Phillips with a small head in the lower left corner.
Two 6 mm Phillips with large heads, one in the upper left corner and one in the middle
Remove the following 15 screws:
Fourteen 3 mm Phillips.
One 5.5 mm Phillips in the upper left corner.
Lift the metal restraining bracket from the hard drive and place it aside.
Remove the following 5 screws and 3 nuts from the heat sink:
One 3.5 mm Phillips from the lower left corner of the heat sink.
Three 6 mm Phillips from around the fan.
One 7.5 mm Phillips at the top right corner of the heat sink.
One 4 mm nut from the side of the heat sink.
Two 4 mm screw nuts with attached springs from either side of the heat sink.
Remove the two Phillips screws securing the white plastic fingers of the I/O bezel to the metal framework.
다른 17명이 해당 안내서를 완성하였습니다.
첨부 문서
댓글 한 개
Just finished putting back together my iBook G4 12inch 1.92. After attempting to repair the infamous soldering issue of these machines, I put it back together and… it works! Thank you for your detailed instructions. If I had one suggestion, please list the screw sizes at all the steps for those putting things back together afterwards. Thank you again!
