주요 콘텐츠로 건너뛰기
소개
This guide is an internal private guide that serves as a prereq.
부품
지정된 부품이 없습니다.
  1. Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • Use a 1.5mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  2. Use your thumbs to slightly separate the rear bezel from the front bezel.
    • Use your thumbs to slightly separate the rear bezel from the front bezel.
    • It is helpful to hold the opposing corner of the display stationary to aid in flexing the rear bezel away from the display.
  3. Insert the flat end of a spudger into the gap between the front and rear bezels. Rotate your spudger until it is parallel to the front face of the display. Run the spudger around the perimeter of the display to separate the rear bezel from its retaining clips.
    • Insert the flat end of a spudger into the gap between the front and rear bezels.
    • Rotate your spudger until it is parallel to the front face of the display.
    • Run the spudger around the perimeter of the display to separate the rear bezel from its retaining clips.
  4. Lift the rear bezel off the display.
    • Lift the rear bezel off the display.
결론
Andrew Bookholt
561,341 평판
안내서 618개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 502
