주요 콘텐츠로 건너뛰기
iBook G4 14" 1.42 GHz DC-In Board Replacement
필요한 것
  1. iBook G4 14" 1.42 GHz DC-In Board Replacement, Battery: 1 단계, 이미지 1/2 iBook G4 14" 1.42 GHz DC-In Board Replacement, Battery: 1 단계, 이미지 2/2
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G4 14" 1.42 GHz DC-In Board Replacement, Lower Case: 2 단계, 이미지 1/1
    • Close the display and flip the computer over.
    • Remove the three hex screws using a T8 Torx screwdriver.
    • The shorter screw is in the center.
  3. iBook G4 14" 1.42 GHz DC-In Board Replacement: 3 단계, 이미지 1/1
    • Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
  4. iBook G4 14" 1.42 GHz DC-In Board Replacement: 4 단계, 이미지 1/1
    • Remove the three newly-revealed Phillips screws.
    • One screw is underneath each bumper (three total).
  5. iBook G4 14" 1.42 GHz DC-In Board Replacement: 5 단계, 이미지 1/1
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
  6. iBook G4 14" 1.42 GHz DC-In Board Replacement: 6 단계, 이미지 1/1
    • Remove the two Phillips screws on either side of the battery contacts.
  7. iBook G4 14" 1.42 GHz DC-In Board Replacement: 7 단계, 이미지 1/1
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push in the thin rims of the lower case surrounding the battery compartment, bending them past the tabs, and then lift up to free that corner of the lower case.
  8. iBook G4 14" 1.42 GHz DC-In Board Replacement: 8 단계, 이미지 1/1
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
  9. iBook G4 14" 1.42 GHz DC-In Board Replacement: 9 단계, 이미지 1/1
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
  10. iBook G4 14" 1.42 GHz DC-In Board Replacement: 10 단계, 이미지 1/1
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
  11. iBook G4 14" 1.42 GHz DC-In Board Replacement: 11 단계, 이미지 1/1
    • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
  12. iBook G4 14" 1.42 GHz DC-In Board Replacement: 12 단계, 이미지 1/1
    • The front and sides of the lower case are now free.
    • Turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free.
    • It may be helpful to jiggle the case up and down.
  13. iBook G4 14" 1.42 GHz DC-In Board Replacement: 13 단계, 이미지 1/1
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
  14. iBook G4 14" 1.42 GHz DC-In Board Replacement, Bottom Shield: 14 단계, 이미지 1/1
    • Remove the following 10 screws from the bottom shield:
    • Six 3 mm Phillips
    • Three 7.5 mm Phillips
    • One 14 mm Phillips
  15. iBook G4 14" 1.42 GHz DC-In Board Replacement: 15 단계, 이미지 1/1
    • Lift the bottom shield off.
  16. iBook G4 14" 1.42 GHz DC-In Board Replacement, DC-In Board: 16 단계, 이미지 1/1
    • Remove the single Phillips screw securing the DC-In board.
  17. iBook G4 14" 1.42 GHz DC-In Board Replacement: 17 단계, 이미지 1/1
    • Angle the DC-In board out of its compartment.
    • You may need to remove tape that secures the DC-In board cable to the case.
  18. iBook G4 14" 1.42 GHz DC-In Board Replacement: 18 단계, 이미지 1/1
    • Lift the DC-In cable from the adhesive attaching it to the logic board.
  19. iBook G4 14" 1.42 GHz DC-In Board Replacement: 19 단계, 이미지 1/1
    • Disconnect the DC-In cable from the logic board.
    • Wiggling the connector parallel to the surface of the logic board while applying slight tension may aid in removal.
결론
다른 63명이 해당 안내서를 완성하였습니다.
첨부 문서
Walter Galan
694,627 평판
안내서 1,203개 작성하였습니다
댓글 4개
On my older iBook G4 the screws where a 5/64 allen head 1.1ghz model
Keith - 답글
it was my first time opening up a laptop and I did not have any problem this tutorial is very helpful because it shows you the process step by step something hard to find nowadays
Baye - 답글
This was a really easy guide thanks. I had ordered a replacement DC in board but found after opening I could have probably repaired the existing one. It had been tripped over a few too many times. I think a bit of re-soldering on the connector where the tape covers in step 17 may have fixed mine. Now I have a backup at least.
datarez - 답글
Hi,
Does anyone happen to know the values of the L2 and L3 parts on this DC-in board?
I am looking to reuse them but I cannot find any specs.
Thank you and regards,
Vincent
Vincent Gerris - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 20,544
