소개
Use this guide to remedy a non-lighting LCD backlight by replacing your blown-out display inverter.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
Remove the two pieces of yellow tape covering the inverter/AirPort cables.
다른 한 분이 해당 안내서를 완성하였습니다.
