이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs (shown in yellow) toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (shown in orange) 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
다른 10명이 해당 안내서를 완성하였습니다.
