주요 콘텐츠로 건너뛰기
iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement
필요한 것
  1. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery out of the computer.
  3. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement, AirPort Extreme Card: 3 단계, 이미지 1개 중 1개
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  4. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement: 4 단계, 이미지 1개 중 1개
    • Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
  5. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement: 5 단계, 이미지 1개 중 1개
    • Grasp the clear plastic tab on the AirPort card and pull toward the display.
  6. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement: 6 단계, 이미지 1개 중 1개
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
결론
다른 19명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
3다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 635개를 작성함
1가이드 댓글
my ibook G4 doesnt have spot for air card to get pluged in it just a RAM im confused how to get internet . please hep fix it
kasey beebe - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 17
전체 시간: 17,454
