주요 콘텐츠로 건너뛰기
iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement
필요한 것
  1. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement, Battery: 1 단계, 이미지 1/1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement: 2 단계, 이미지 1/1
    • Lift the battery out of the computer.
  3. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement, AirPort Extreme Card: 3 단계, 이미지 1/1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  4. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement: 4 단계, 이미지 1/1
    • Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
  5. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement: 5 단계, 이미지 1/1
    • Grasp the clear plastic tab on the AirPort card and pull toward the display.
  6. iBook G4 14" 933 MHz-1.33 GHz AirPort Extreme Card Replacement: 6 단계, 이미지 1/1
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
결론
다른 19명이 해당 안내서를 완성하였습니다.
첨부 문서
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 한 개
my ibook G4 doesnt have spot for air card to get pluged in it just a RAM im confused how to get internet . please hep fix it
kasey beebe - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 17,219
