주요 콘텐츠로 건너뛰기
iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement
필요한 것
  1. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery out of the computer.
  3. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement, Lower Case: 3 단계, 이미지 1개 중 1개
    • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
  4. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the three newly-revealed Phillips screws.
  5. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement: 5 단계, 이미지 1개 중 1개
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
  6. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the three hex screws using a T8 Torx screwdriver (or Allen screws using an Allen key if these are used).
    • The shorter screw is in the center of the computer.
  7. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws on either side of the battery contacts.
  8. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement: 8 단계, 이미지 1개 중 1개
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
  9. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement: 9 단계, 이미지 1개 중 1개
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    • Be careful not to break this clip!
  10. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement: 10 단계, 이미지 1개 중 1개
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
  11. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement: 11 단계, 이미지 1개 중 1개
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
  12. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement: 12 단계, 이미지 1개 중 1개
    • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
  13. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement: 13 단계, 이미지 1개 중 1개
    • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
  14. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
  15. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement, Bottom Shield: 15 단계, 이미지 1개 중 1개
    • Remove the following 10 screws from the bottom shield:
    • Six 3 mm Phillips
    • Three 7.5 mm Phillips
    • One 14 mm Phillips
  16. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement: 16 단계, 이미지 1개 중 1개
    • Lift the bottom shield off.
  17. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement, Battery Connector: 17 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws securing the battery connector.
  18. iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement: 18 단계, 이미지 1개 중 1개
    • Lift the battery connector out of the metal framework and disconnect it from the logic board.
    • The connector may not come free easily. Wiggle it from side to side as you pull it steadily out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
2다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 635개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 8,639
