소개
The metallic bottom shield protects the logic board from electromagnetic interference.
필요한 것
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Remove the following 10 screws from the bottom shield:
Six 3 mm Phillips
Three 7.5 mm Phillips
One 14 mm Phillips
거의 끝나갑니다!
결론
다른 7명이 해당 안내서를 완성하였습니다.
