주요 콘텐츠로 건너뛰기
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Lift the battery out of the computer.
    • Lift the battery out of the computer.
  3. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a pin (or anything you like) to remove the three rubber feet from the lower case.
    • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the three newly-revealed Phillips screws.
    • Remove the three newly-revealed Phillips screws.
  5. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
  6. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the three hex screws using a T8 Torx screwdriver (or Allen screws using an Allen key if these are used).
    • Remove the three hex screws using a T8 Torx screwdriver (or Allen screws using an Allen key if these are used).
    • The shorter screw is in the center of the computer.
  7. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the two Phillips screws on either side of the battery contacts.
    • Remove the two Phillips screws on either side of the battery contacts.
  8. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
  9. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    • Be careful not to break this clip!
  10. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
  11. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
  12. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
    • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
  13. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
    • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
  14. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the small greasy springs with white plastic caps from either side of the battery contacts.
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
  15. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the following 10 screws from the bottom shield:
    • Remove the following 10 screws from the bottom shield:
    • Six 3 mm Phillips
    • Three 7.5 mm Phillips
    • One 14 mm Phillips
  16. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Lift the bottom shield off.
    • Lift the bottom shield off.
  17. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the single Phillips screw securing the DC-In board.
    • Remove the single Phillips screw securing the DC-In board.
  18. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Disconnect the DC-In cable from the logic board.
    • Disconnect the DC-In cable from the logic board.
  19. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Deroute the cable from around the optical drive, removing tape as necessary, and angle the DC-In board out of its compartment.
    • Deroute the cable from around the optical drive, removing tape as necessary, and angle the DC-In board out of its compartment.
결승점
다른 69명이 해당 안내서를 완성하였습니다.
첨부 문서
iRobot
회원 가입일: 2009년 09월 24일
1 평판
안내서 647개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 42,998
