이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Replace the display inverter with the display assembly still attached to your computer.
필요한 것
Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
Remove the two pieces of yellow tape covering the inverter/AirPort cables.
다른 3명이 해당 안내서를 완성하였습니다.
