소개
Save money by replacing just the LCD rather than the whole display.
필요한 것
Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
거의 끝나갑니다!
결론
다른 5명이 해당 안내서를 완성하였습니다.
