주요 콘텐츠로 건너뛰기
iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement
필요한 것
  1. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement, Battery: 1 단계, 이미지 1/1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: 2 단계, 이미지 1/1
    • Lift the battery out of the computer.
  3. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement, Rear Display Bezel: 3 단계, 이미지 1/2 iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement, Rear Display Bezel: 3 단계, 이미지 2/2
    • Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  4. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: 4 단계, 이미지 1/2 iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: 4 단계, 이미지 2/2
    • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
    • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  5. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: 5 단계, 이미지 1/1
    • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  6. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: 6 단계, 이미지 1/2 iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: 6 단계, 이미지 2/2
    • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  7. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: 7 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
    • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
  8. iBook G4 14" 933 MHz-1.33 GHz Rear Display Bezel Replacement: 8 단계, 이미지 1/1
    • Lift the rear bezel off the display assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
첨부 문서
Andrew Bookholt
587,723 평판
안내서 619개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,413
