주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Removing the rear display bezel does not require removal of the display assembly.
  1. Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  2. Lift the battery out of the computer.
    • Lift the battery out of the computer.
  3. Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total). If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
    • Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
    • If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
  4. Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display. Rotate the spudger away from the display to pry the rear bezel off the front bezel.
    • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
    • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
  5. Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
    • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
  6. Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display. Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
    • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
  7. Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
    • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
    • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
  8. Lift the rear bezel off the display assembly.
    • Lift the rear bezel off the display assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
첨부 문서
Andrew Bookholt
547,252 평판
안내서 618개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 2,251
