주요 콘텐츠로 건너뛰기
iDea USA CT 1020 Screen Replacement
필요한 것
  1. iDea USA CT 1020 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Start by powering off the device.
    • Place the device on a clean surface with the screen facing down.
  2. iDea USA CT 1020 Screen Replacement: 2 단계, 이미지 1/2 iDea USA CT 1020 Screen Replacement: 2 단계, 이미지 2/2
    • Gently apply pressure to the back of the device where the backing case and screen meet.
  3. iDea USA CT 1020 Screen Replacement: 3 단계, 이미지 1/2 iDea USA CT 1020 Screen Replacement: 3 단계, 이미지 2/2
    • Using a spudger or an iFixit opening tool, lift and release the camera assembly ZIF tabs.
    • Gently pull the ribbon cable free.
    • Repeat this for the other tab.
  4. iDea USA CT 1020 Screen Replacement: 4 단계, 이미지 1/3 iDea USA CT 1020 Screen Replacement: 4 단계, 이미지 2/3 iDea USA CT 1020 Screen Replacement: 4 단계, 이미지 3/3
    • Remove the disconnected camera by simply pulling it out of its socket.
    • Remove eight 25mm JIS #00 screws securing the motherboard.
    • The battery is glued to the back of the screen. Gently pry the battery off the screen, being careful not the bend the battery.
  5. iDea USA CT 1020 Screen Replacement: 5 단계, 이미지 1/1
    • Remove ten 25mm JIS #00 screws securing the screen.
  6. iDea USA CT 1020 Screen Replacement: 6 단계, 이미지 1/2 iDea USA CT 1020 Screen Replacement: 6 단계, 이미지 2/2
    • Wedge the edges of the opening tools into the gap between the screen and the screen casing.
    • Be very careful while prying the screen from its casing to avoid damage.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nathanael Carlson
회원 가입일: 01/08/18
183 평판
안내서 1개 작성함
IUPUI, Team S1-G3, Freund Spring 2018 IUPUI, Team S1-G3, Freund Spring 2018 회원
IUPUI-FREUND-S18S1G3
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
SOOOOO GOOD , Well done
Nathanael Carlson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 153
