주요 콘텐츠로 건너뛰기
iDea USA CT702 Button Replacement
필요한 것
  1. iDea USA CT702 Button Replacement, Button: 1 단계, 이미지 1/3 iDea USA CT702 Button Replacement, Button: 1 단계, 이미지 2/3 iDea USA CT702 Button Replacement, Button: 1 단계, 이미지 3/3
    • Place the device face up.
    • Use a plastic opening tool to gently pry open the black panel around the portholes.
  2. iDea USA CT702 Button Replacement: 2 단계, 이미지 1/3 iDea USA CT702 Button Replacement: 2 단계, 이미지 2/3 iDea USA CT702 Button Replacement: 2 단계, 이미지 3/3
    • Pry the rest of the back off; slowly apply pressure from each side to break each clip connection.
  3. iDea USA CT702 Button Replacement: 3 단계, 이미지 1/2 iDea USA CT702 Button Replacement: 3 단계, 이미지 2/2
    • With a plastic spudger tool, pry the keys away from the black key mat to remove them.
    • It is easiest to start with the volume up button key and then work on freeing the next two.
  4. iDea USA CT702 Button Replacement: 4 단계, 이미지 1/2 iDea USA CT702 Button Replacement: 4 단계, 이미지 2/2
    • Replace the button keys, starting with the outer and ending with the innermost key.
    • The back of each button key has a notch that matches an indent on the black button mat. Match the notches and the indents to properly align the buttons.
    • To replace the back cover, follow the first three steps in reverse order.
결론
Daniel Brandt
회원 가입일: 03/11/15
201 평판
안내서 2개 작성하였습니다
Colorado Springs, Team 4-7, Panko Spring 2015 Colorado Springs, Team 4-7, Panko Spring 2015 회원
UCCS-PANKO-S15S4G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 134
