주요 콘텐츠로 건너뛰기
iDea USA CT702 Digitizer Glass Replacement
필요한 것
  1. iDea USA CT702 Digitizer Glass Replacement, Digitizer Glass: 1 단계, 이미지 1/1
    • Place tablet on the table with screen facing upright.
    • Starting from the portholes, use plastic opening tool to pry in between the front panel and back cover.
    • Follow the opening along the corners and sides until all latches are unclipped.
    • Remove back cover completely and place it outside of the work area.
  2. iDea USA CT702 Digitizer Glass Replacement: 2 단계, 이미지 1/2 iDea USA CT702 Digitizer Glass Replacement: 2 단계, 이미지 2/2
    • Place tablet facing down.
    • Locate the 4mm screws along the perimeter of the motherboard.
    • There should be 4 screws.
    • Use Philips screw driver to unscrew each one, and carefully place screws in a safe place.
  3. iDea USA CT702 Digitizer Glass Replacement: 3 단계, 이미지 1/3 iDea USA CT702 Digitizer Glass Replacement: 3 단계, 이미지 2/3 iDea USA CT702 Digitizer Glass Replacement: 3 단계, 이미지 3/3
    • After screws are removed, gently pull up on the ribbon wire connection to release all 3 wires from the motherboard.
    • Safely remove mother board and battery from tablet by using tweezers.
    • Make sure the small ribbon wires are not damaged when removing larger members.
  4. iDea USA CT702 Digitizer Glass Replacement: 4 단계, 이미지 1/1
    • Remove tape from battery pack, and dispose.
    • Be careful not to touch the wire/battery connection correctly, as it could result in injury.
  5. iDea USA CT702 Digitizer Glass Replacement: 5 단계, 이미지 1/3 iDea USA CT702 Digitizer Glass Replacement: 5 단계, 이미지 2/3 iDea USA CT702 Digitizer Glass Replacement: 5 단계, 이미지 3/3
    • After removing the battery pack and motherboard, the touch sensor unit should be visible.
    • Use small Philips screw driver to unscrew all 6 of the 2mm screws.
    • Use fingers and prying tool to remove the touch sensor unit from frame.
  6. iDea USA CT702 Digitizer Glass Replacement: 6 단계, 이미지 1/3 iDea USA CT702 Digitizer Glass Replacement: 6 단계, 이미지 2/3 iDea USA CT702 Digitizer Glass Replacement: 6 단계, 이미지 3/3
    • After the touch sensor is detached, only the plastic screen should remain.
    • Insert new touch sensor plate into the same position, aligning all screw inputs.
    • Insert all six of the 2mm. screws to connect the new touch sensor to the screen frame.
  7. iDea USA CT702 Digitizer Glass Replacement: 7 단계, 이미지 1/1
    • To continue reassembling the tablet, follow the steps in reverse.
    • Be careful when reconnecting battery, use safety goggles and gloves.
  8. iDea USA CT702 Digitizer Glass Replacement: 8 단계, 이미지 1/3 iDea USA CT702 Digitizer Glass Replacement: 8 단계, 이미지 2/3 iDea USA CT702 Digitizer Glass Replacement: 8 단계, 이미지 3/3
    • To reassemble tablet, follow these steps in reverse order.
결론
David Kambich
회원 가입일: 03/11/15
110 평판
안내서 1개 작성함
Colorado Springs, Team 4-7, Panko Spring 2015 Colorado Springs, Team 4-7, Panko Spring 2015 회원
UCCS-PANKO-S15S4G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 325
