주요 콘텐츠로 건너뛰기
iDea USA CT702 Microphone Replacement
필요한 것
  1. iDea USA CT702 Microphone Replacement, Microphone: 1 단계, 이미지 1/1
    • Place the tablet face up with portholes facing you.
  2. iDea USA CT702 Microphone Replacement: 2 단계, 이미지 1/2 iDea USA CT702 Microphone Replacement: 2 단계, 이미지 2/2
    • Use a fingernail, or a plastic opening tool to gently pry the black panel around the portholes.
    • Be gentle and take your time. Excessive force could damage the device.
  3. iDea USA CT702 Microphone Replacement: 3 단계, 이미지 1/3 iDea USA CT702 Microphone Replacement: 3 단계, 이미지 2/3 iDea USA CT702 Microphone Replacement: 3 단계, 이미지 3/3
    • Use your fingers to pry the rest of the back off; slowly apply pressure from each side to break each clip connection.
  4. iDea USA CT702 Microphone Replacement: 4 단계, 이미지 1/1
    • Once the back is off, position the tablet as shown and be sure to warm your soldering iron.
  5. iDea USA CT702 Microphone Replacement: 5 단계, 이미지 1/1
    • Place tip of the soldering iron on the end of the wire to break connection.
    • Remember to use proper safety precautions when soldering.
  6. iDea USA CT702 Microphone Replacement: 6 단계, 이미지 1/1
    • Grip the new microphone with tweezers and place in the slot.
    • Solder the new connections while using tweezers to hold the speaker steady.
결론
Benton Gray
회원 가입일: 03/11/15
201 평판
안내서 2개 작성하였습니다
Colorado Springs, Team 4-7, Panko Spring 2015 Colorado Springs, Team 4-7, Panko Spring 2015 회원
UCCS-PANKO-S15S4G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 111
